Shows statistics IP Network Address Translation (NAT) statistics (byte/packet counters) in the outward direction.
ip | Specifies Internet Protocol (IP). |
nat | Specifies NAT. |
rule | Specifies NAT rules. |
rule_name | Specifies displaying statistics only for the specified NAT rule. |
statistics | Specifies showing IP NAT rule statistics. |
no-refresh | Specifies displaying page-by-page without auto-refresh. |
N/A.
The following example shows NAT statistics in the outward direction:
# show ip nat rule statistics NAT Rule Statistics Sat Sep 11 16:27:23 2019 NAT Rule Name Tx Packet Tx Byte ================================ ===================== ===================== nat59 2168 138752 nat60 2168 138752 nat61 2168 138752 nat62 2168 138752 nat63 2168 138752 nat64 2168 138752 nat65 2168 138752 nat66 2168 138752 nat67 2168 138752 nat68 2168 138752 nat69 2168 138752 nat70 2168 138752 nat71 2168 138752 nat72 2168 138752 nat73 2168 138752 nat74 2168 138752 nat75 2168 138752 nat76 2168 138752 nat77 2168 138752 ============================================================================== 0->Clear Counters U->page up D->page down ESC->exit
This command was first available in ExtremeXOS 31.2.
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
